I have Desktop 10.4.x installed on my machine and when I try to upgrade to the latest x-ray for ArcCatalog and ArcMap, only ArcMap worked. The files were downloaded from http://www.arcgis.com/home/item.html?id=9ea218ff575f4a5195e01a2cae03a0ae (arccatalog) & https://www.arcgis.com/home/item.html?id=f0ae73e90c1a4992a1059e7d370966d4 (arcmap). Before today's update, I already have X-Ray enabled in my ArcCatalog but it was an old version. I go to Add-In Manager and delete the old add-in in Catalog and before double clicking on the new ones. After installing with successful message, I notice that for both Add-Ins there are added to the 10.2 folder rather than then 10.4 folder under the User/Documents/ArcGIS/Addins folder. I rename the destination folder and double click to install the add-ins, and a new 10.2 folder gets created. When I go to ArcMap, I am able to view the Add-In in the Add-in Manager. However, in Catalog, I am unable to. I try to do it manually via Customize Mode, I get this message "No GUI components found in this Add-In. Add-In version does not match. " I try using the Manager and navigate to the folder where the Add-Ins reside, nothing happens. No error message no changes either.
I no longer have old X-Ray for ArcCatalog available. Anything else I can try to get this working? This current version should work with 10.4.1 right?
