Hi, I'm trying to join attributes from 12 tables to a single layer. This is the script.
import arcpy
from arcpy import env
# Set overwrite option
arcpy.env.qualifiedFieldNames = False
# Set the current workspace.
env.workspace = r'D:\INSUMOS\INEGI\21 Puebla.mdb'
# Set local variables.
inFeatures = r'D:\INSUMOS\INEGI\21 Puebla.mdb\JOIN\mNoJoin'
layerName = 'mNoJoin_layer'
joinField = 'CVEGEO'
outFeature = r'D:\INSUMOS\INEGI\21 Puebla.mdb\JOIN\m_Join'
# Create a feature layer from the vegtype featureclass.
arcpy.MakeFeatureLayer_management (inFeatures, layerName)
# Get a list of stand alone tables in the geodatabase and print out.
tableList = arcpy.ListTables("*manzanas*")
for table in tableList:
# Join the feature layer to a tables.
arcpy.AddJoin_management(layerName, joinField, tableList, joinField)
# Copy the layer to a new permanent feature class
arcpy.CopyFeatures_management(layerName, outFeature)
print "Number of tables joined to inFeature: ", len(tableList)
print "Done."
I get this from Shell:
File "D:\Eric\python script\AddMultipleJoinToFeature.py", line 24, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 6110, in AddJoin
raise e
RuntimeError: Object: Error in executing tool
I suppose this a newbie stuff, but I appreciate if you guys help me.
