I have an existing app that has a FeatureTable populated by a FeatureLayer that has been created client side from the results of a query. I recently migrated the app from 3.16 to 3.17 and was pleased to see that a few issues have been resolved but a new one popped up which is that I can no longer sort the table.
When I click on the column header I don't get the popup menu that allows the user to choose ascending or descending. I also don't get any console errors.
To show what I mean, I combined these two samples, Feature collection | ArcGIS API for JavaScript 3.17 and Using FeatureTable | ArcGIS API for JavaScript 3.17. That code is listed below.
Any ideas are appreciated!
Thanks!
Jill
<!DOCTYPE html>
<html>
<head>
<title>Using FeatureTable</title>
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://community.esri.com//js.arcgis.com/3.17/esri/css/esri.css">
<script src="//js.arcgis.com/3.17/"></script>
<style>
html, body, #map{
width:100%;
height:100%;
margin:0;
padding:0;
</style>
<script>
var map;
require([
"esri/layers/FeatureLayer",
"esri/dijit/FeatureTable",
"esri/geometry/webMercatorUtils",
"esri/map",
"dojo/dom-construct",
"dojo/dom",
"dojo/parser",
"dojo/ready",
"dojo/on",
"dojo/_base/lang",
"dijit/registry",
"dijit/form/Button",
"dijit/layout/ContentPane",
"dijit/layout/BorderContainer",
"dijit/form/TextBox",
"esri/request",
"dojo/_base/array",
"esri/geometry/Point",
"esri/graphic"
], function (
FeatureLayer, FeatureTable, webMercatorUtils, Map,
domConstruct, dom, parser, ready, on,lang,
registry, Button, ContentPane, BorderContainer, TextBox, esriRequest, array, Point, Graphic
parser.parse();
ready(function(){
var myFeatureLayer;
var map = new Map("map",{
basemap: "dark-gray"
map.on("load", loadTable);
function loadTable(){
//create a feature collection for the flickr photos
var featureCollection = {
"layerDefinition": null,
"featureSet": {
"features": [],
"geometryType": "esriGeometryPoint"
featureCollection.layerDefinition = {
"geometryType": "esriGeometryPoint",
"objectIdField": "ObjectID",
"drawingInfo": {
"renderer": {
"type": "simple",
"symbol": {
"type": "esriPMS",
"url": "images/flickr.png",
"contentType": "image/png",
"width": 15,
"height": 15
"fields": [{
"name": "ObjectID",
"alias": "ObjectID",
"type": "esriFieldTypeOID"
"name": "description",
"alias": "Description",
"type": "esriFieldTypeString"
"name": "title",
"alias": "Title",
//create a feature layer based on the feature collection
myFeatureLayer = new FeatureLayer(featureCollection, {
//set map extent
on(myFeatureLayer, "load", function(evt){
var extent = myFeatureLayer.fullExtent;
if (webMercatorUtils.canProject(extent, map)) {
map.setExtent( webMercatorUtils.project(extent, map) );
map.addLayer(myFeatureLayer);
myFeatureTable = new FeatureTable({
"featureLayer" : myFeatureLayer,
"map" : map
}, 'myTableNode');
myFeatureTable.startup();
requestPhotos();
function requestPhotos() {
//get geotagged photos from flickr
//tags=flower&tagmode=all
var requestHandle = esriRequest({
url: "https://api.flickr.com/services/feeds/geo?&format=json",
callbackParamName: "jsoncallback"
requestHandle.then(requestSucceeded, requestFailed);
function requestSucceeded(response, io) {
//loop through the items and add to the feature layer
var features = [];
array.forEach(response.items, function(item) {
var attr = {};
attr["description"] = item.description;
attr["title"] = item.title ? item.title : "Flickr Photo";
var geometry = new Point(item);
var graphic = new Graphic(geometry);
graphic.setAttributes(attr);
features.push(graphic);
myFeatureLayer.applyEdits(features, null, null);
function requestFailed(error) {
console.log('failed');
</script>
</head>
<body class="claro esri">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center', splitter:true" style="height:50%">
<div id="map"></div>
</div>
<div id="bot" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'bottom', splitter:true" style="height:50%">
<div id="myTableNode"></div>
</div>
</div>
</body>
</html>
