Hi Jamal,The far right of the Status Bar in ArcPad is used for 2 things:1. Double-tap to display memory indicators. If there are 2 memory indicators, the icon with the green 'V' denotes the virtual memory. Double-tap a second time to dismiss the memory indicators.[ATTACH=CONFIG]30478[/ATTACH]2. The value in the Status Bar (V, H or Z) indicates the action button mode. This is for Windows Mobile devices that have a rocker button (+ and -) to navigate around your device. ArcPad allows you to use this hardware button to navigate around your map. By performing a press and hold on the rocker you can toggle through the following options:Z mode: fixed zoom in/outH mode: horizontal panV mode: vertical pan Hope this helps,Hannah 🙂
