While we are waiting for the release of a new version the Electric Utility Network Foundation template for Enterprise 10.8.1....Is there an upgrade process for the template v3.4 to work with ArcGIS 10.8.1/Pro2.6?
We have configured ArcGIS Enterprise 10.8.1 (ArcGIS Pro 2.6, Oracle 19c) and tried to load the Electric v3.4 template. Apply package with loading the sample data failed with the following message:
Current state: Run apply Package - failed\
The asset package has the following warnings (1/1):
Item Field OID Value Message Level
0 ElectricCrossarm length None None This field name is reserved on some database platforms warning
C:\Users\xyz\AppData\Local\ESRI\conda\envs\arcgispro-py3-clone\Lib\site-packages\pandas\core\frame.py:1487: FutureWarning: Using short name for 'orient' is deprecated. Only the options: ('dict', list, 'series', 'split', 'records', 'index') will be used in a future version. Use one of the above to silence this warning.
FutureWarning,
Failed to execute (AssetPackageToUtilityNetwork).
Should we use ArcGIS Pro 2.5 (untools2.5?) with ArcGIS Enterprise 10.8.1 to load & configure the Electric template 3.4? Again, we understand that the best approach is to wait for the next release of the Electric template, ... just want to explore options to move forward now with the sample data set and configuration from the Electric template v3.4.
