When I add the map service in ArcGIS.com I can get a list of layers that are able to be turned on and off.
When I add the same service to my javascript viewer (template viewer) I only get one layer which is the service name. From what I can tell it looks like I should be getting a list of layers that can be toggled on and off as well:
function addLayerList(layers) { var layerList = buildLayerVisibleList(layers); if (layerList.length > 0) { //create a menu of layers layerList.reverse(); var menu = new dijit.Menu({ id: 'layerMenu', baseClass: "customMenu" }); dojo.forEach(layerList, function (layer) { menu.addChild(new dijit.CheckedMenuItem({ label: layer.title, checked: layer.visible, onChange: function () { if (layer.layer.featureCollection) { //turn off all the layers in the feature collection even //though only the main layer is listed in the layer list dojo.forEach(layer.layer.featureCollection.layers, function (layer) { layer.layerObject.setVisibility(!layer.layerObject.visible); }); } else { layer.layer.setVisibility(!layer.layer.visible); } } })); }); var button = new dijit.form.DropDownButton({ label: i18n.tools.layers.label, id: "layerBtn", iconClass: "esriLayerIcon", title: i18n.tools.layers.title, dropDown: menu }); dojo.byId('webmap-toolbar-center').appendChild(button.domNode); } } //build a list of layers for the toggle layer list - this list //is slightly different than the legend because we don't want to list lines,points,areas etc for each //feature collection type. function buildLayerVisibleList(layers) { var layerInfos = []; dojo.forEach(layers, function (mapLayer, index) { if (mapLayer.featureCollection && !mapLayer.layerObject) { if (mapLayer.featureCollection.layers) { //add the first layer in the layer collection... not all - when we turn off the layers we'll //turn them all off if (mapLayer.featureCollection.layers) { layerInfos.push({ "layer": mapLayer, "visible": mapLayer.visibility, "title": mapLayer.title }); } } } else if (mapLayer.layerObject) { layerInfos.push({ layer: mapLayer.layerObject, visible: mapLayer.layerObject.visible, title: mapLayer.title }); } }); return layerInfos; }
