I'm trying to get a small form (for adding comments) working in a popup. To do this, I'm trying to add a dom event listener when the popup is visible, but getElementById (aka byId) can't find the button element. This tries to add it whether the popup is visible or not, but you get the idea -
view<SPAN class="punctuation token">.</SPAN>popup<SPAN class="punctuation token">.</SPAN><SPAN class="token function">watch</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"visible"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>visible<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"popup visible: "</SPAN><SPAN class="punctuation token">,</SPAN> visible<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> btn<SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">try</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="comment token">//view.popup.renderNow(); // seems to do bupkis</SPAN>
btn <SPAN class="operator token">=</SPAN> dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"btnAddComment"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"watch btn is "</SPAN><SPAN class="punctuation token">,</SPAN> btn<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN>dom<SPAN class="punctuation token">.</SPAN><SPAN class="token function">byId</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"btnAddComment"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"clicky"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">catch</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="token class-name">err</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>btn<SPAN class="punctuation token">,</SPAN> err<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>The template is super simple, based on the popup intro example -
var template = { // autocasts as new PopupTemplate()
title: "Marriage in NY, Zip Code: {ZIP}",
content: "<button id='btnAddComment'>Add Comment</button>"
<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I've got a codepen of this if you want to see the rest of the code. Pretty sure I did something like this in 3.x, really not sure why it's not working here. Thanks!
