All,I'm working on an application where I need to turn layers on/off. I thought it best to build a basemap on AGOL, pull that in using the webmap ID method, then add layers on top of that. However, whenever I try adding a new layer using the CSVLayer module, my basemap will not load. Can someone help me out?Thanks!
<script src="http://js.arcgis.com/3.9/"></script>
<script>
require([
"dojo/parser",
"dojo/ready",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dojo/dom",
"esri/map",
"esri/urlUtils",
"esri/arcgis/utils",
"esri/dijit/Legend",
"esri/dijit/Scalebar",
"dojo/domReady!"
], function(
parser,
ready,
BorderContainer,
ContentPane,
dom,
Map,
urlUtils,
arcgisUtils,
Legend,
Scalebar
ready(function(){
parser.parse();
arcgisUtils.createMap("Some IDNUM","map").then(function(response){
//update the app
dom.byId("title").innerHTML = response.itemInfo.item.title;
dom.byId("subtitle").innerHTML = response.itemInfo.item.snippet;
var map = response.map;
//add the scalebar
var scalebar = new Scalebar({
map: map,
scalebarUnit: "english"
//add the legend. Note that we use the utility method getLegendLayers to get
//the layers to display in the legend from the createMap response.
var legendLayers = arcgisUtils.getLegendLayers(response);
var legendDijit = new Legend({
map: map,
layerInfos: legendLayers
},"legend");
legendDijit.startup();
</script>
