I'm trying to remove a layer from my map. this code: arcpy.AddMessage(str(arcpy.mapping.ListLayers (mxd, "", df)))
arcpy.AddMessage(addstru)
arcpy.mapping.RemoveLayer (df, addstru)
gets me this result:[<map layer u'StruxPts_v04'>, <map layer u'Land_Projects_Parcels_P6'>]StruxPts_v04[<map layer u'StruxPts_v04'>, <map layer u'Land_Projects_Parcels_P6'>]As you can see, the layer 'StruxPts_v04' was not removed. When does this sort of thing occur?Thanks!EDIT: I'm thinking it has something to do with my searchcursor. addstru is searched, but I delete the cursor's variables prior to the code above.
