I'm more of a desktop GIS developer, and I need some web GIS programming help. The following URLs are public. The JavaScript isn't obfuscated, so you should be able to see and read the source in developer mode within your browser.
First, check out https://maps.orem.org/MeterSearch.htm . This web page can take two parameters in the URL. You can append "?id=1234" to have the map zoom to a particular water meter ID, like 1234. You should be able to also append an address with an addr query parameter. The idea is that, if the meter can't be found by ID, then at least the address should be geocoded and the map should zoom in just like when the water meter ID is found. So, if a negative meter ID is used above, and the house address is off by 2, the URL would look like this:
https://maps.orem.org/MeterSearch.htm?id=-1234&addr=575+E+Heather+Road
It should zoom to Heather Road, but it doesn't work. Just so you know, the underlying geocoder is a custom one that I built which queries the geodatabase directly. It uses a metaphone algorithm, linear algebra, dynamic segmentation, QGrams, and Utah house/street number switching to find the correct point. A sample REST request for the address above would look like this, using an offset of 100 feet:
https://maps.orem.org/Geocoding/OremGeocoder.dll/rest/GeocodedAddress/?addr=98+N+State+Street&Offset=100
The response is: {"x":1945693.56472451,"y":716049.690701424,"spatialReference":{"wkid":32043}}
The hyperlink to the meter map which includes the sample address should zoom to the suburbs. The error I see in JavaScript is this:
dojo.js:354 [esri.core.accessorSupport.write] web-document-write:property-required Missing value for required property 'x' on 'esri.geometry.Point'
Clearly, x is in the REST response from the geocoder, so I'm lost. Please help me fix this, ESRI Community!
"Roj"
