I am using a FGDB feature class that has a field called "MgmtTractID" of string type. It has the exact same properties and name as a field in my feature class in an SDE geodatabase. Unfortunately, the attributes from MgmtTractID in my FGDB will not transfer to the SDE MgmtTractID field. I'm not sure why, if I use the Append tool (with selections on my FGDB feature class) in the GUI, it works fine. I use "NO_TEST" because some of the fields aren't common between the two feature classes. I have also checked with a search cursor that my feature layer contains the values I would like to transfer.
arcpy<SPAN class="punctuation token">.</SPAN>Append_management<SPAN class="punctuation token">(</SPAN>mgmtTractFL<SPAN class="punctuation token">,</SPAN> db_mgmtTractFC<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'NO_TEST'</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN></SPAN>
The documentation for the Append tool states this:
Map layers can be used as Input Datasets. If a layer has a selection, only the selected records (features or table rows) are used by the Append tool.
So why doesn't it work?
