I'm a bit frustrated with Esri Maps for Office mapping by Congressional Districts. The districts (as I understand it) are delineated via FIPS codes- and the corresponding numerals or letters.
STATE AL
STATEFP 01
CD113FP 6
NAMELSAD Congressional District 6
So I would think the minimum data fields you would need is STATEFP and CD113FP.
BUT, when you add your data via Excel and Esri Maps for Office and you select "More..." under Location Type and scroll down to US and Congressional Districts, then add your data- you are prompted to point to a single column for "Choose the location information columns" and "Select location columns to continue". So although is says "columns" plural- I don't see how to select more than one... See my line above- you need to ID by state and Cong. Dist.
What am I doing wrong? Or is this just not possible? I get errors on every row that is to be plotted...Nothing on the map. And I don't see how to fix the errors.
