I'm trying to implement identify across multiple services (with multiple layers). I'm having trouble with the asynchronous processing of the identify task. I've seen sucessful code in silver light/flex api, but can't seem to make it work in the javascript api.I've tried a couple of different approaches by using the dojo.deferred object returned by the identify task or breaking out the callbacks into a separate functions, but I'm apparently dense on how to control the flow of execution using dojo. Any suggestions are appreciated. My test at the end of the forEach service loop, tab container hasChildren(), is ALWAYS false, even though I can see results in the content pane object and the tab container object are correct. I understand why it is happening, but not versed enough in javascript in general to know how to fix the issue and process synchronously.Thanks,Susan>>execution order >>1>>3>>2console.log("execution order");
console.log("1");
dojo.forEach(loadedServices, function(service) {
mapService = map.getLayer(service);
layerids.length = 0; //reset layerids array
if (mapService.visibleLayers.length > 0) { //does service have visible layers?
url = mapService.url; //get url of service
identifyTask = new esri.tasks.IdentifyTask(url); //ceate new identify task
identifyParams.layerIds = mapService.visibleLayers; //other params set in init function
//var idDeferred = identifyTask.execute(identifyParams); //tried using return deferred object
//idDeferred.then(function(idResults) { //results the same, not right approach
identifyTask.execute(identifyParams,
//populate object for service and visible layers
if (idResults.length>0) {
console.log("2"); //execution order, understand it is async
cp = new dijit.layout.ContentPane ({ //create a new tab for each service results
title: service,
style: "height:100px; width: 300px; color:#000000 background-image:none;background-color:transparent;"
addToCP(idResults); //process results into contentPane
tc.addChild(cp); //add contentPane to tab container
console.log(tc.hasChildren()); //is true....
function(err) {
console.log("doIdentify: (" + err.name + ") " + err.message);
console.log("3");
console.log(tc);
if (tc.hasChildren()) { //is always false due to
tc.startup();
map.infoWindow.setContent(tc.domNode);
map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
} else {
alert('No results found, please check layer visibility and try again.');
