I cannot get the Cut GeometryService to work properly in FireFox. It works great in IE and Chrome.Sample code is here:It is designed for cutting of polygons. You may need to adjust proxy and FeatureLayer when testing locally.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>JavaScript API Cut Test</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.6/js/esri/css/esri.css" />
<style>
html,body{height:100%;width:100%;margin:0;overflow:hidden;}
#map{
padding:0;
#header{
font-size: 1.1em;
font-family: sans-serif;
padding-left: 1em;
padding-top:4px;
color:#660000;
.templatePicker {
border: none;
.dj_ie .infowindow .window .top .right .user .content { position: relative; }
.dj_ie .simpleInfoWindow .content {position: relative;}
</style>
<script src="http://js.arcgis.com/3.6/"></script>
<script>
var map;
require([
"esri/map",
"esri/toolbars/edit",
"esri/dijit/editing/Cut",
"esri/toolbars/draw",
"esri/layers/ArcGISTiledMapServiceLayer",
"esri/layers/FeatureLayer",
"esri/tasks/query",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"esri/tasks/QueryTask",
"esri/dijit/editing/Editor",
"esri/dijit/editing/TemplatePicker",
"esri/tasks/GeometryService",
"esri/config","esri/dijit/editing/Union","esri/graphic",
"dojo/i18n!esri/nls/jsapi",
"dojo/_base/array", "dojo/parser", "dojo/keys","dojo/on","dijit/registry","dojo/_base/lang",
"dijit/layout/BorderContainer", "dijit/layout/ContentPane",
"dojo/domReady!"
], function(
Map, Edit,Cut, Draw,
ArcGISTiledMapServiceLayer, FeatureLayer,Query,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, QueryTask,
Editor, TemplatePicker, GeometryService,
esriConfig, Union, Graphic,jsapiBundle,
arrayUtils, parser, keys, on,registry, lang
parser.parse();
// refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html
//esriConfig.defaults.io.proxyUrl = "http://localhost/proxy/proxy.ashx";
esriConfig.defaults.io.proxyUrl = "/proxy";
var geometryService = new GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
map = new Map("map", {
basemap: "streets",
center: [-96.541, 38.351],
zoom: 13
var cutService;
var unionService;
var donutService;
var waterbodies = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Hydrography/Watershed173811/FeatureServer/0",{
outFields: ['*']
var fieldsSelectionSymbol = new SimpleFillSymbol().setColor(new dojo.Color([255,255,0,0.5]));
fieldsSelectionSymbol.setOutline(new SimpleLineSymbol("dashdot", new dojo.Color([255,0,0]), 2));
waterbodies.setSelectionSymbol(fieldsSelectionSymbol);
map.addLayers([waterbodies]);
function SelectionSet(geometries, tb) {
tb.deactivate();
var selectQuery = new Query();
selectQuery.geometry = geometries;
waterbodies.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW);
function PerformCut() {
var selectGraphics = waterbodies.getSelectedFeatures();
if (selectGraphics.length == 0){
alert("Select a polygon to slice.");
return;
else if (selectGraphics.length > 1){
alert("More than one polygon is currently selected. The slice operation can only be done on one polygon.");
return;
var sliceGeometry = selectGraphics[0].geometry;
var tbSlice = new Draw(map);
//find points in Extent when user completes drawing extent
on(tbSlice, "DrawEnd", function(polyline){
splitLineComplete(polyline);
tbSlice.activate(Draw.POLYLINE);
function splitLineComplete(polyline) {
if (polyline) {
var selectGeometries = new Array();
var sliceGraphics = waterbodies.getSelectedFeatures();
for (var i = 0; i < sliceGraphics.length; i++) {
selectGeometries.push(sliceGraphics.geometry);
geometryService.cut(selectGeometries,polyline);
cutService = geometryService.on("cut-complete", function(results) {
tbSlice.deactivate(Draw.POLYLINE);
if (results.result.geometries != null && results.result.geometries.length > 1) {
var cutGraphic = waterbodies.getSelectedFeatures()[0].setGeometry(results.result.geometries[0]);
// Create for the next
currentSymbolCut = waterbodies.getSelectedFeatures()[0].symbol;
currentAttributesCut = lang.clone(cutGraphic.attributes);
var newGraphics = new Array();
for (var i = 1; i < results.result.geometries.length; i++) {
newGraphics.push(new Graphic(results.result.geometries, currentSymbolCut,currentAttributesCut));
waterbodies.applyEdits(newGraphics, [cutGraphic], null, CutSucceed, CutFailed);
function CutSucceed() {
cutService.remove();
clearTool();
function CutFailed(evt) {
alert("Failed - " + evtObj);
GenFunc.clearTool();
function SelectFeatures() {
var tb = new Draw(map);
on(tb, "DrawEnd", function(geometries){
tb.activate(Draw.EXTENT);
var bSelect = registry.byId("btnSelect");
on(bSelect, "click", function(evt){
SelectFeatures();
var bSlice = registry.byId("btnSplit");
on(bSlice, "click", function(evt){
PerformCut();
var bClear = registry.byId("btnClear");
on(bClear, "click", function(evt){
clearTool(waterbodies);
function clearTool(waterbodies){
map.graphics.clear();
if (waterbodies) {
waterbodies.clearSelection();
waterbodies.refresh();
</script>
</head>
<body class="claro">
<div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
<div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
</div>
<div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
<div id="templateDiv"></div>
<div id="editorDiv"></div>
<br>
<div id="btnSelect" data-dojo-type="dijit/form/Button" style='padding-left:5px;'>Select</div>
<br>
<div id="btnSplit" data-dojo-type="dijit/form/Button" style='padding-left:5px;'>Cut</div>
<br>
<div id="btnClear" data-dojo-type="dijit/form/Button" style='padding-left:5px;'>Clear</div>
<br>
<br>
<span><u>Steps</u></span>
<br>
<br>
<span>1. Select one polygon</span>
<br>
<br>
<span>2. Click the Cut button and draw a line through the selected polygon</span>
<br>
<br>
<span>3. Polygon will should now be split.</span>
</div>
<div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
</div>
</body>
</html>
