Just wanted to report a possible bug I found in the Beta 2 Developers Edition. It is not reproducible in the Online Version but I am using Custom Widgets and themes so I can't switch. Thanks!
When I configure a popup in my AGOL map and save it (even if
I have made no changes) the popup in my web app builder no longer works.
It pops up but there are no data fields, labels or title.
Browser: Chrome
App is hosted on IIS 7
Steps to reproduce:
- Create a fully editable feature layer and add to
an AGOL map - Add the AGOL map to the web app builder
- Enable popup in AGOL map and save map , just
take the default and do not configure (popup should now work in the web app
builder) - In the AGOL map, Configure the popup, save the
configuration and save the map - Now popup is blank in the web app builder
This is causing me some trouble, especially where I need to
format a dateStamp with date and time. Also the other widgets such as
edit use the same configuration so it is a problem when trying to edit… i.e.
you can enter a date but not the time. In AGOL if I format the popup for
date and time the popup creates 2 fields for editing – this would be nice to
have in the app builder as well.
