HiI'm attempting to build a tool that will use Con to highlight overlap between two input raster values by producing an output raster with 1s and 0s.However, even in a most simple form with a single raster and condition I can't seem to assign a constant value for the false condition. The code below results in the error:"0" does not existCurrently using 10.2.import arcpy
import arcpy.sa as sa
# input raster
ras1 = r"D:\mal\Soil_Type.tif"
# value of ras1 to be evaluated as true
class1 = 3
# Define output layer
ras_output = (r"D:\mal\soils.gdb\soiltype_overlap")
ras3 = sa.Con(ras1 == class1, 1, 0)
ras3.save(ras_output)
I can't work out what I am doing wrong here, as the syntax seems to be consistent with all help examples.Any advice appreciatedCheersMalcolm
