Getting an error I don't understand. Working with an SDE geodatabase in ArcMap. Everything is at 10.2.1. I bring in feature classes from a feature dataset using a user that is the data owner. When I try to reconcile with the parent version, I get the following error:
The version could not be reconciled. Insufficient permissions [geodatabasename.parentversion.featureclassname]. The workspace is not connected.
The feature class named in the error is in a different feature dataset, and the user is the owner of that feature dataset too. As far as I can tell, the permissions are set up the same on all feature classes. Why is it freaking out about a feature class that I'm not even referencing? What workspace do I need to connect to? I can reconcile and post versions further down the hierarchy.
wtf sde?
