I am still somewhat raw with python, although I am learning and trying to develop some tools. What I do need help with is a script tool which creates an index of rasters. It was created by someone who no longer works here anymore. He was fairly advanced with python and he created a wide variety of script tools. The tool in question does almost exactly what I need, however I would like it to avoid certain file extensions (.OVR, .TOC). I am just unsure of where to place a statement in the code to have these file types ignored.
Hopefully someone can help out.
Here is the code
# Description:
# Generate footprints for all raster products within a directory. Can
# optionally perform a recursive traverse to find all rasters within the
# tree.
# Produces a single shapefile output with attributes to identify each raster
# dataset found.
# ArcGIS Version: 10.0
# Python Version: 2.6
import arcpy
import datetime
import os
import sys
def message(msg, severity=0):
"""Notify the user of some event with a message.
Arcpy does not print messages to command line, and print statements
do not appear within the Arc runtime. This method can act as a global
notification system for both environments.
# print a message to the command line
print msg
# notify the user within the arc environment
# splits a message on \n, making a notification for each line in a
# multiline string
try:
for string in msg.split('\n'):
# add message under appropriate severity
if severity == 0:
arcpy.AddMessage(string)
elif severity == 1:
arcpy.AddWarning(string)
elif severity == 2:
arcpy.AddError(string)
except:
# ignore errors
pass
def listRasters(rasterTypes = "ALL"):
"""Generate a list of rasters found within a workspace."""
# keep a list of all files for all types
foundFiles = []
if rasterTypes == "ALL":
# just gather all file types
foundFiles = arcpy.ListRasters("*", rasterTypes)
else:
# arcpy will not let us specify multiple file types to search for, so
# we replicate that ability by appending the file lists for each
# specified file type.
fileTypes = rasterTypes.split(';')
for fileType in fileTypes:
foundFiles.extend(arcpy.ListRasters("*", fileType))
# return all discovered files
return foundFiles
def processRasterList(shapefile, rasterList):
"""Process a list of rasters into coordinates and attributes."""
# make sure there is some data to be processed
# if no data is found, notify the user and move on
if not len(rasterList):
message("No rasters found.")
return
# notify the user work is starting
message("Processing %d rasters." % len(rasterList))
arcpy.SetProgressor("step",
"Processing rasters...",
0,
len(rasterList))
# keep track of if we find any projected data
projDataFound = False
for rasterStr in rasterList:
# inform the user which raster is being processed
arcpy.SetProgressorLabel("Processing %s" % rasterStr)
# Wrap the whole thing in a try block to catch possible problems
# Problems are ignored, and the user is notified that a raster was
# not processed.
try:
# make a raster object
raster = arcpy.Raster(rasterStr)
except:
message("Processing raster failed: %s" % rasterStr, 1)
message(arcpy.GetMessages(2), 1)
# abondon this raster and move on
continue
# notify the user if projected data is found (prefer geographic)
if raster.spatialReference.type == "Unknown":
projDataFound = True
# generate an array to hold each corner of the raster
coords = arcpy.Array()
# add each corner of the raster to the array
coords.add(raster.extent.lowerLeft)
coords.add(raster.extent.upperLeft)
coords.add(raster.extent.upperRight)
coords.add(raster.extent.lowerRight)
# Polygons require the start coordinate to match the end coordinate
# make a polygon from the points array
rasterPolygon = arcpy.Polygon(coords, raster.spatialReference)
try:
# use an insert cursor to create new records for this raster
fcRows = arcpy.InsertCursor(shapefile, )
# make a new row
row = fcRows.newRow()
# set all the attributes
row.shape = rasterPolygon
row.path = raster.path
row.filename = raster.name
row.type = raster.format
row.process_d = str(datetime.date.today())
row.num_rows = raster.height
row.num_cols = raster.width
row.xmin = raster.extent.XMin
row.xmax = raster.extent.XMax
row.ymin = raster.extent.YMin
row.ymax = raster.extent.YMax
row.Projection = raster.spatialReference.name
row.datum = raster.spatialReference.spheroidName
row.epsg_code = raster.spatialReference.factoryCode
row.num_bands = raster.bandCount
row.pixelw = raster.meanCellWidth
row.pixelh = raster.meanCellHeight
row.bit_depth = int(raster.pixelType[1:])
row.comptype = raster.compressionType
# insert the row into the featureclass
fcRows.insertRow(row)
# free up some memory
del row
del fcRows
del coords
except:
message("Cataloging raster failed: %s" % rasterStr, 1)
# update the progress bar position
arcpy.SetProgressorPosition()
# notify the user if any unprojected data was found
if projDataFound:
message("Unprojected data found. Check outputs.", 1)
# reset the progress bar to normal
arcpy.SetProgressorLabel("Looking for rasters...")
arcpy.ResetProgressor()
def create_featureclass(fcPath, inMemory=False):
"""Create a shapefile to store all the data that is collected from a raster
list. Also adds all fields required for metadata about each raster.
# split the path into its component parts
(dirName, fileName) = os.path.split(fcPath)
# make all outputs WGS84 Geographic
spatialReference = os.path.join(arcpy.GetInstallInfo()["InstallDir"],
r"Coordinate Systems\Geographic Coordinate Systems\World\WGS 1984.prj")
# get a path to the template shapefile
tmplShp = os.path.abspath(os.path.join(os.path.dirname(sys.argv[0]),
'data',
'raster_index_tmpl.shp'))
# check if creating feature in memory
if inMemory == "true":
dirName = "in_memory"
fileName = "memoryindex"
# create the featureclass
arcpy.CreateFeatureclass_management(dirName,
fileName,
"POLYGON",
tmplShp,
"DISABLED",
"DISABLED",
spatialReference)
return os.path.join(dirName, fileName)
## fields come from the template shapefile, this is just for reference
## # add appropriate fields to the featureclass
## arcpy.AddField_management(fcPath, 'Path', 'TEXT', 254)
## arcpy.AddField_management(fcPath, 'Filename', 'TEXT', 254)
## arcpy.AddField_management(fcPath, 'Type', 'TEXT', 16)
## arcpy.AddField_management(fcPath, 'Process_D', 'DATE')
## arcpy.AddField_management(fcPath, 'NUM_Rows', 'LONG')
## arcpy.AddField_management(fcPath, 'NUM_Cols', 'LONG')
## arcpy.AddField_management(fcPath, 'XMin', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'XMax', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'YMin', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'YMax', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'Projection', 'TEXT', 50)
## arcpy.AddField_management(fcPath, 'Datum', 'TEXT', 50)
## arcpy.AddField_management(fcPath, 'EPSG_Code', 'TEXT', 6)
## arcpy.AddField_management(fcPath, 'NUM_Bands', 'SHORT')
## arcpy.AddField_management(fcPath, 'PixelW', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'PixelH', 'FLOAT', 15, 10)
## arcpy.AddField_management(fcPath, 'BIT_DEPTH', 'SHORT')
## arcpy.AddField_management(fcPath, 'Compression', 'TEXT', 20)
def index_rasters(inputWorkspace, outputFeatureClass, processRecursive,
inMemoryProcessing, fileTypes = ""):
"""Process all rasters within a given directory."""
# notify if using in memory processing
if inMemoryProcessing == "true":
message("Using in memory processing")
# support the ability to index multiple directories at the same time, either
# as recursive or not.
inputWorkspaces = inputWorkspace.split(';')
for inWS in inputWorkspaces:
# arc wraps directories in quotes for fun
inWS = inWS.replace("'", "")
# set the workspace to be the base directory from the user
arcpy.env.workspace = inWS
# if the user doesn't want to process only certain files, set "ALL"
if fileTypes == "":
fileTypes = "ALL"
try:
# create a featureclass to hold all raster metadata
if len(inputWorkspaces) == 1 or not arcpy.Exists(outputFeatureClass):
featureData = create_featureclass(outputFeatureClass,
inMemoryProcessing)
# Determine if recursive. No need to walk if not doing a recursive
# list.
if processRecursive == 'false':
message("Gathering raster list from %s" % arcpy.env.workspace)
rasterList = listRasters(fileTypes)
processRasterList(featureData, rasterList)
else:
message("Recursive processing started.")
for root, dirs, files in os.walk(inWS):
# have to do this once for the top level folder
arcpy.env.workspace = root
## for subdir in dirs:
## arcpy.env.workspace = os.path.join(root, subdir)
## message("Gathering raster list from %s" % arcpy.env.workspace)
## rasterList = listRasters(fileTypes)
## processRasterList(outputFeatureClass, rasterList)
# if processing was done in memory, write items to disk
arcpy.Merge_management(featureData, outputFeatureClass)
# delete the in memory feature class
arcpy.Delete_management(featureData)
except arcpy.ExecuteError:
print arcpy.GetMessages(2)
arcpy.AddError(arcpy.GetMessages(2))
except Exception as e:
print e.args[0]
arcpy.AddError(e.args[0])
# Test how the script is running. This allows it to run from multiple
# environments, or to be included as a module into another script without
# destroying environments.
if __name__ == '__main__':
# gather all arguments that have been passed in
argv = tuple(arcpy.GetParameterAsText(i)
for i in xrange(arcpy.GetArgumentCount()))
index_rasters(*argv)
