I'm using the address management template and workflows for a Statewide street centerline data set. When adding a streetname to the Master Address Guide the streetname needs to be unique using a zipcode. I've added the zipcode to the Local Government Master Street Guide.
What attribute assistant expression do I use to choose the new street name so that it matches the zipcode polygon in the Map document or the editor has added the correct zipcode in the centerline attribute.
Charline Avey
techhowgirl@gmail.com
