Hi esri community,I'm trying to use a fairly simple script to export a list of map layouts (mxds) in a folder to pngs. should be easy but...import arcpy
ws = arcpy.env.workspace = "X:\\Draft3Maps"
outDir = "X:\\Draft3_Map_graphics"
mapList = arcpy.ListFiles("*.mxd")
arcpy.mapping.MapDocument(mapList)
for mxd in mapList:
#arcpy.mapping.MapDocument(mxd)
print mxd
arcpy.mapping.ExportToPNG(mxd, outDir + '\\' + str(mxd))
del mxd
Error message:Traceback (most recent call last): File "X:\export_mxd_to_PNG.py", line 8, in <module> arcpy.mapping.MapDocument(mapList) File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 443, in __init__ assert (os.path.isfile(mxd) or (mxd.lower() == "current")), gp.getIDMessage(89004, "Invalid MXD filename") File "C:\Apps\Python26\ArcGIS10.0\lib\genericpath.py", line 29, in isfile st = os.stat(path)TypeError: coercing to Unicode: need string or buffer, list foundI know I'm probably close but probably missing something key. Any help is greatly appreciated.Rich
