I keep getting error 000117 (empty output generated) when I try intersecting a shapefile with my boundary. I have deleted and recalculated the extents. As well as deleted the spatial index. Neither helped.
I also tried clip (same error), and split (error 999999).
The other shapefile that I needed to split based on the same boundaries worked just fine using the intersect tool. I cannot find any differences in the properties between the two.
Any suggestions on what I can try to split my shapefile?
