The script below multiplies two rasters, where the cell value of one raster is a parameter.#Import modules
import os
import arcpy
from arcpy import env
from arcpy.sa import *
#Set local variables
wks = arcpy.GetParameterAsText(0) # input workspace
inRaster1 = arcpy.GetParameterAsText(1) # input raster layer
env.workspace = wks
#Perform Constant Raster Function
constantValue = arcpy.GetParameterAsText(2) # input weight value
cellSize = 100
outExtent = Extent(871599.89, 982834.44, 912502.09, 1070920.9)
outConstRaster = CreateConstantRaster(constantValue, "FLOAT", cellSize, outExtent)
outConstRaster.save("temp1")
#Perform Times Function
outTimes = Raster(inRaster1)* Raster("temp1")
outRaster1 = "Wt_" + os.path.basename(inRaster1)
outTimes.save(outRaster1)
#Create script output and delete constant raster
arcpy.SetParameterAsText(3,outRaster1)
arcpy.Delete_management("temp1")
This works, but is not optimal and much slower than I would like. I tried this code without saving outConstRaster and just calling it as a raster object, but I kept getting the same error: "TypeError: expected a raster or layer name." This will also need to work for up to 10 different raster layers.Any thoughts on making this more efficient?
