Hello folks,
I have to work with txt files that contain special (non-ascii) characters like in "Temperature (°C)" or "Chl_A (µg/L)".
When I read the field names directly from the table with utf-8 encoding and list them in Python I get 'Temperature (\xc2\xb0C)' and 'Chl_A (\xb5g/L)'.
I receive the names of the fields to work on from a script tool where the validation tool reads the field names (with utf-8 encoding) and gives them back as a list to chose from (where they look "properly spelled"). These chosen ones are then received from my python script with GetParameterAsText and then split up.
fieldnames<SPAN class="operator token">=</SPAN>arcpy<SPAN class="punctuation token">.</SPAN>GetParameterAsText<SPAN class="punctuation token">(</SPAN><SPAN class="number token">3</SPAN><SPAN class="punctuation token">)</SPAN>
fieldnameslist<SPAN class="operator token">=</SPAN>fieldnames<SPAN class="punctuation token">.</SPAN>split<SPAN class="punctuation token">(</SPAN><SPAN class="string token">";"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN></SPAN>
When I read and write those I get [u"'Chl_A (\xb5g/L)'", u"'Temperature (\xb0C)'"]
Note also the difference between the first and the second output: (\xc2\xb0C) and (\xb0C) which seem to be two different unicode encodings. When I read them again in a new list with utf-8 encoding I get ["'Chl_A (\xc2\xb5g/L)'", "'Temperature (\xc2\xb0C)'"]
Now when I try to use the field name again to read from the table the values I need for further calculations the field name is not recognised and I guess that is because of the encoding. Interestingly (at least for me), when I read from the utf-8 list or from the other the field name I get again "Temperature (°C)" or "Chl_A (µg/L)" as an output. So I assume I have to "translate" the symbols back into hexa spelling to be able to communicate with the txt file.
When I hardcode the field name to be 'Chl_A (\xb5g/L)' in the arcpy.message I still get Chl_A (µg/L) but then the search cursor complains that "'utf8' codec can't decode byte 0xb5 in position 7: invalid start byte". When I use u'Chl_A (\xb5g/L)' the field name is recognized.
How can I give the field names from my list so that the script can read them and they are recognized in the table again for the search cursor?
I'm using Python 2.7.14 with ArcMap 10.6.1
PS: Looking for further information I tumbled over this read, which might give you something to laugh for today: The Absolute Minimum Every Software Developer Absolutely, Positively Must Know About Unicode and Character Sets (No Excu… (plus some well explained information I think, but it didn't help solve my problem...).
