Hi all,
There are some things I would like to customize in the Web App that I'm making and I will appreciate your help:
first - you need to know that I built the app in arcgis online and then downloaded the code and deployed it from my server.
Now i'm trying to configure it in my server.
1. I'm using the JewelryBox Theme. I would like to make the header panel more wide, so I can put there a larger logo. where do I change the parameters of the panel hight? (I saw that it is seperated to "header section" and "container section")
2. still in the header panel - how do I change its color?
3. Widgets in the header panel: I want to remove the "layer list" widget from there. what do I need to do? (deleting its folder from the widgets folder is not enogh)
this is it for now.
Thanks for all the helpers!
Dikla.
