I want to show label for feature points after a query is executed using the Query Widget.
For the query widget, I edited for following code in the widget.js file:
//create a FeatureLayer
_createNewResultLayer: function(currentAttrs, queryName){
var resultLayer = null;
var renderer = null;
var taskIndex = currentAttrs.queryTr.taskIndex;
var layerInfo = lang.clone(currentAttrs.layerInfo);
//override layerInfo
layerInfo.name = queryName;
//ImageServiceLayer doesn't have drawingInfo
if (!layerInfo.drawingInfo) {
layerInfo.drawingInfo = {
"showLabels":true
layerInfo.drawingInfo.transparency = 0;
layerInfo.minScale = 0;
layerInfo.maxScale = 0;
layerInfo.effectiveMinScale = 0;
layerInfo.effectiveMaxScale = 0;
layerInfo.defaultVisibility = true;
delete layerInfo.extent;
//only keep necessary fields
var singleQueryLoader = new SingleQueryLoader(this.map, currentAttrs);
var necessaryFieldNames = singleQueryLoader.getOutputFields();
layerInfo.fields = array.filter(layerInfo.fields, lang.hitch(this, function(fieldInfo) {
return necessaryFieldNames.indexOf(fieldInfo.name) >= 0;
var featureCollection = {
layerDefinition: layerInfo,
featureSet: null
//For now, we should not add the FeatureLayer into map.
resultLayer = new FeatureLayer(featureCollection,{
showLabels: true
// resultLayer.keepResultsOnMapAfterCloseWidget = currentAttrs.config.keepResultsOnMapAfterCloseWidget;
//set taskIndex for resutlLayer
resultLayer._queryWidgetTaskIndex = taskIndex;
//set popupTemplate
var popupInfo = lang.clone(currentAttrs.config.popupInfo1);
var popupTemplate = new PopupTemplate(popupInfo);
console.log(popupInfo);
if(popupInfo.showAttachments){
var url = currentAttrs.config.url;
var objectIdField = currentAttrs.config.objectIdField;
queryUtils.overridePopupTemplateMethodGetAttachments(popupTemplate, url, objectIdField);
resultLayer.setInfoTemplate(popupTemplate);
var labelingInfo= lang.clone(currentAttrs.config.labelingInfo1);
console.log(labelingInfo)
var labelClass = new LabelClass(labelingInfo);
resultLayer.labelsVisible = true;
resultLayer.labelingInfo = [labelClass];
resultLayer.setLabelingInfo([labelClass]);
currentAttrs.query.resultLayer = resultLayer;
