Using Following code from ArcGIS JavaScript API 3.21 , I am trying to display a converted map to kmz file by ArcMap at ArcGIS JavaScript API
<SPAN class="keyword token">var</SPAN> map<SPAN class="punctuation token">;</SPAN>
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"esri/map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/KMLLayer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dojo/parser"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/dom-style"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"dijit/layout/BorderContainer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dijit/layout/ContentPane"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"dojo/domReady!"</SPAN>
<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>
Map<SPAN class="punctuation token">,</SPAN> KMLLayer<SPAN class="punctuation token">,</SPAN>
parser<SPAN class="punctuation token">,</SPAN> domStyle
<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"map"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"topo"</SPAN><SPAN class="punctuation token">,</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">108.663</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">42.68</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">6</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
parser<SPAN class="punctuation token">.</SPAN><SPAN class="token function">parse</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> kmlUrl <SPAN class="operator token">=</SPAN> <SPAN class="string token"><SPAN>"</SPAN><A class="jive-link-external-small" href="https://community.esri.com/external-link.jspa?url=http%3A%2F%2Fmydomain.com%2Fdata%2Fapp.kmz" target="_blank">http://mydomain.com/data/app.kmz</A><SPAN>"</SPAN></SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="keyword token">var</SPAN> kml <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">KMLLayer</SPAN><SPAN class="punctuation token">(</SPAN>kmlUrl<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN>kml<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
kml<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"load"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
domStyle<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">set</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"loading"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"display"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"none"</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>I have an .mxd map which looks like with an inserted white TEXT "Map Of Some Where" in the middle. I used the Map to KML tool to export the map to kml file
but the output on ArcGIS API looks like when I load it to API map (Without inserted TEXT)
Can you please let me know why this is happening and how I can fix this?
