I've Feature Class which keeps changing (e.g. S_pol_Din_DepL82270692015146eAnt015130) and I would like use Arcpy to replace a text (like 2015178eAnt015146) from him field (d2clust200m). Some rows are empty, e.g <Null>, and I don't want change them. But, I can't use replace with a text from ListFeatureClass, it shows that is done, But, isn't.
The text that will be replaced is always the same from the last piece's name from the another FC (it always starts with "pol_din").
If it's too hard be done by arcpy, I can use MB. Or even replace just what isn't null.
Next, I show all tries I've done.
<SPAN class="keyword token">import</SPAN> arcpy
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token"># Local variables:</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>env<SPAN class="punctuation token">.</SPAN>workspace <SPAN class="operator token">=</SPAN> r<SPAN class="string token">'C:\Teste_Auto_CLEIA\Auto_Classi\Dinamica_GDB.gdb'</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#List FC # line 6</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> FC <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"S_pol_Din*"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> Feature <SPAN class="operator token">=</SPAN> FC<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"Feature: "</SPAN><SPAN class="operator token">+</SPAN>str<SPAN class="punctuation token">(</SPAN>Feature<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> strFeature <SPAN class="operator token">=</SPAN> str<SPAN class="punctuation token">(</SPAN>Feature<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"strFeature: "</SPAN><SPAN class="operator token">+</SPAN>strFeature
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#List FC # line 13</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> FCName <SPAN class="operator token">=</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>ListFeatureClasses<SPAN class="punctuation token">(</SPAN><SPAN class="string token">"pol*"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> FC_Name <SPAN class="operator token">=</SPAN> FCName<SPAN class="punctuation token">[</SPAN><SPAN class="number token">1</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"FC_Name: "</SPAN><SPAN class="operator token">+</SPAN>str<SPAN class="punctuation token">(</SPAN>FC_Name<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> FCNameCut <SPAN class="operator token">=</SPAN> FC_Name<SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">17</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">]</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"FCNameCut "</SPAN><SPAN class="operator token">+</SPAN>FCNameCut
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#Calculate field (D2clust200m) #Line 20</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> arcpy<SPAN class="punctuation token">.</SPAN>CalculateField_management <SPAN class="punctuation token">(</SPAN>Feature<SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"D2clust200m"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"!D2clust200m!.replace('"</SPAN><SPAN class="string token">'FCNameCut'</SPAN><SPAN class="string token">"', \"test\")"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"PYTHON"</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"Try 1 Calculated"</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#Calculate field (D2clust200m) </SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#arcpy.CalculateField_management (Feature, "D2clust200m", "!D2clust200m!.replace(\"FCNameCut\", \"test\")","PYTHON")</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#print"2nd try Calculated"</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#arcpy.CalculateField_management (Feature, "D2clust200m", '!D2clust200m!.replace('"'FCNameCut'"', '"'test'"')',"PYTHON")</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#print"Try 3 Calculated"</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#Calculate field (D2clust200m) #This one works if I don't use a list's word </SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#arcpy.CalculateField_management (Feature, "D2clust200m", '!D2clust200m!.replace(\"FCNameCut\", \"test\")',"PYTHON")</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="comment token">#print"4th try Calculated"</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN> <SPAN class="keyword token">print</SPAN><SPAN class="string token">"Done"</SPAN>
Feature<SPAN class="punctuation token">:</SPAN> S_pol_Din_DepL82270692015146eAnt015130
strFeature<SPAN class="punctuation token">:</SPAN> S_pol_Din_DepL82270692015146eAnt015130
FC_Name<SPAN class="punctuation token">:</SPAN> pol_Din_DepL82270692015178eAnt015146
FCNameCut 2015178eAnt015146
Try <SPAN class="number token">1</SPAN> Calculated
Done<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Thanks
*I'm using Arcmap 10.4 with Python 2.7, but I appreciate if it works on ArcMap 10.1
