When I try to identify a feature, the IdentifyTask's execute function is invoking an error that simply contains the message "Unable to complete operation."The strange thing is, this identify function works as it should when I use it at either the map's full extent or a specific extent of a feature (when I zoom to a feature via the results in a Datagrid), but once I pan the map even slightly out of that specific extent, the IdentifyTask throws that error.My code is listed in the following. It's a loose interpretation of the "Identify features on a map" sample provided by ArcGIS.doIdentify = function(evt) {
// Hide the previous results
myMap.infoWindow.hide();
var task = null;
var params = null;
task = new esri.tasks.IdentifyTask(url.baseMap);
params = new esri.tasks.IdentifyParameters();
params.tolerance = 4;
params.returnGeometry = true;
params.layerIds = [3, 4, 5, 6];
params.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
params.width = myMap.width;
params.height = myMap.height;
params.geometry = evt.mapPoint;
params.mapExtent = myMap.extent;
task.execute(params, function(idResults) {
identifyInfoWin(idResults, evt);
}, function(err) {
console.log("doIdentify: (" + err.name + ") " + err.message);
I consider myself well-acquainted with the ArcGIS JS API, but I have been staring at this problem for much too long without seeking help.Thanks in advance
