I am using ArcPy to export data driven pages to PNGs. I need the export to have a higher resolution then the default one when you export your map using ArcPy.
This is the script that I am using
mxd = arcpy.mapping.MapDocument("CURRENT")
for pageNum in range(1, mxd.dataDrivenPages.pageCount + 1):
mxd.dataDrivenPages.currentPageID = pageNum
pageName = str(mxd.dataDrivenPages.pageRow.New_ID)
arcpy.mapping.ExportToPNG(mxd, r"C:\Users\" + pageName + ".png")
del mxd
I want the resolution to be 200.
Where would I add this into the script?
