I'm very new to Esri and by no means a GIS professional either. So please forgive me if what I'm asking seems noobish.
We have a need to display an Esri map that a visitor can add a marker onto to report an incident. Before the visitor reports the incident we'd like to load all previously reported incidents onto the map so the visitor can see if their incident has been previously reported.
My plan is to have the user select an class of incident and we'd then load those incidents from a Json source into a FeatureLayer. If the user changes the incident class we'd hide that FeatureLayer and load the newly selected incident classes from json, into another FeatureLayer, etc.
I'm using Vue and have imported the esri-loader. I followed some examples of loading data from Json into a FeatureSet, but nothing appears on my map.
I can put symbols onto the data layer and that works, but I thought FeatureLayers would be the best place to put my user data.
I'd be grateful if someone could take a look at my code and advise on if the approach I'm using is even valid or where I'm making a mistake in adding to and showing the layer.
<SPAN class="operator token"><</SPAN>template<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"main"</SPAN><SPAN class="operator token">></SPAN>
ref<SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN>
<SPAN class="keyword token">class</SPAN><SPAN class="operator token">=</SPAN><SPAN class="string token">"map"</SPAN>
<SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>template<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="keyword token">import</SPAN> <SPAN class="punctuation token">{</SPAN> loadScript<SPAN class="punctuation token">,</SPAN> loadModules <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">from</SPAN> <SPAN class="string token">'esri-loader'</SPAN>
<SPAN class="comment token">// preload the ArcGIS API</SPAN>
<SPAN class="keyword token">const</SPAN> options <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
url<SPAN class="punctuation token">:</SPAN> '<SPAN class="comment token">//js.arcgis.com/3.27/',</SPAN>
<SPAN class="token function">loadScript</SPAN><SPAN class="punctuation token">(</SPAN>options<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">export</SPAN> <SPAN class="keyword token">default</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">data</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">{</SPAN>
map<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
userLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
Map<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
GraphicsLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
Point<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
SimpleMarkerSymbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
Graphic<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
FeatureLayer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
FeatureSet<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
SimpleRenderer<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="token function">mounted</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">loadModules</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">'esri/map'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/layers/GraphicsLayer'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/geometry/Point'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'esri/symbols/SimpleMarkerSymbol'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/graphic'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">'esri/layers/FeatureLayer'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">'esri/renderers/SimpleRenderer'</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>Map<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> Point<SPAN class="punctuation token">,</SPAN> SimpleMarkerSymbol<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> FeatureLayer<SPAN class="punctuation token">,</SPAN>
SimpleRenderer<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>Map <SPAN class="operator token">=</SPAN> Map
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>GraphicsLayer <SPAN class="operator token">=</SPAN> GraphicsLayer
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>Point <SPAN class="operator token">=</SPAN> Point
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>SimpleMarkerSymbol <SPAN class="operator token">=</SPAN> SimpleMarkerSymbol
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>Graphic <SPAN class="operator token">=</SPAN> Graphic
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>FeatureLayer <SPAN class="operator token">=</SPAN> FeatureLayer
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>SimpleRenderer <SPAN class="operator token">=</SPAN> SimpleRenderer
<SPAN class="comment token">// create map with the given options</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>Map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>$refs<SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1.2040487</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">52.7690669</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
basemap<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'topo'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'load'</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> renderer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SimpleRenderer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
symbol<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">markerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">let</SPAN> fields <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'ObjectId'</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'ObjectId'</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'number'</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'lat'</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'lat'</SPAN><SPAN class="punctuation token">,</SPAN>
name<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'lng'</SPAN><SPAN class="punctuation token">,</SPAN>
alias<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'lng'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">let</SPAN> data <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN>
lat<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1.1260934</SPAN><SPAN class="punctuation token">,</SPAN>
lng<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">52.6670721</SPAN>
lat<SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">1.17365</SPAN><SPAN class="punctuation token">,</SPAN>
lng<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">52.7515022</SPAN>
<SPAN class="keyword token">let</SPAN> points <SPAN class="operator token">=</SPAN> data<SPAN class="punctuation token">.</SPAN><SPAN class="token function">map</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">(</SPAN>point<SPAN class="punctuation token">,</SPAN> idx<SPAN class="punctuation token">)</SPAN> <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
geometry<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Point</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
x<SPAN class="punctuation token">:</SPAN> point<SPAN class="punctuation token">.</SPAN>lng<SPAN class="punctuation token">,</SPAN>
y<SPAN class="punctuation token">:</SPAN> point<SPAN class="punctuation token">.</SPAN>lat
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN>
attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
ObjectId<SPAN class="punctuation token">:</SPAN> idx<SPAN class="punctuation token">,</SPAN>
lat<SPAN class="punctuation token">:</SPAN> point<SPAN class="punctuation token">.</SPAN>lat<SPAN class="punctuation token">,</SPAN>
lng<SPAN class="punctuation token">:</SPAN> point<SPAN class="punctuation token">.</SPAN>lng
<SPAN class="keyword token">let</SPAN> featureCollection <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">{</SPAN>
layerDefinition<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
geometryType<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'esriGeometryPoint'</SPAN><SPAN class="punctuation token">,</SPAN>
fields<SPAN class="punctuation token">:</SPAN> fields<SPAN class="punctuation token">,</SPAN>
spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN>
featureSet<SPAN class="punctuation token">:</SPAN> points
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>userLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>FeatureLayer</SPAN><SPAN class="punctuation token">(</SPAN>featureCollection<SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN>
supportsEditting<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
supportsAdd<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
source<SPAN class="punctuation token">:</SPAN> points<SPAN class="punctuation token">,</SPAN>
renderer<SPAN class="punctuation token">:</SPAN> renderer<SPAN class="punctuation token">,</SPAN>
objectIdField<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'ObjectId'</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>userLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setRenderer</SPAN><SPAN class="punctuation token">(</SPAN>renderer<SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN><SPAN class="token function">addLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>userLayer<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">.</SPAN><SPAN class="keyword token">catch</SPAN><SPAN class="punctuation token">(</SPAN>err <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">error</SPAN><SPAN class="punctuation token">(</SPAN>err<SPAN class="punctuation token">)</SPAN> <SPAN class="comment token">// eslint-disable-line no-console</SPAN>
methods<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="token function">markerSymbol</SPAN><SPAN class="punctuation token">(</SPAN>color<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> markerSymbol <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>SimpleMarkerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> color<SPAN class="punctuation token">,</SPAN>
size<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">60</SPAN><SPAN class="punctuation token">,</SPAN>
angle<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
xoffset<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
yoffset<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">30</SPAN><SPAN class="punctuation token">,</SPAN>
outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
color<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">5</SPAN><SPAN class="punctuation token">,</SPAN>
type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'esriSLS'</SPAN><SPAN class="punctuation token">,</SPAN>
style<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">'esriSLSSolid'</SPAN>
markerSymbol<SPAN class="punctuation token">.</SPAN><SPAN class="token function">setPath</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">'M256,0C167.641,0,96,71.625,96,160c0,24.75,5.625,48.219,15.672,69.125C112.234,230.313,256,512,256,512l142.594-279.375 C409.719,210.844,416,186.156,416,160C416,71.625,344.375,0,256,0z M256,256c-53.016,0-96-43-96-96s42.984-96,96-96 c53,0,96,43,96,96S309,256,256,256z'</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">return</SPAN> markerSymbol
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN>
<SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN>
@<SPAN class="keyword token">import</SPAN> <SPAN class="token function">url</SPAN><SPAN class="punctuation token">(</SPAN>'<SPAN class="comment token">//js.arcgis.com/3.27/esri/css/esri.css');</SPAN>
<SPAN class="punctuation token">.</SPAN>map <SPAN class="punctuation token">{</SPAN>
height<SPAN class="punctuation token">:</SPAN> 500px<SPAN class="punctuation token">;</SPAN>
<SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>If I write direct to the graphics layer with the following I can get markers displayed:
<SPAN class="keyword token">let</SPAN> points <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1.1260934</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">52.6670721</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="operator token">-</SPAN><SPAN class="number token">1.17365</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">52.7515022</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">]</SPAN>
points<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN>point <SPAN class="operator token">=</SPAN><SPAN class="operator token">></SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="keyword token">let</SPAN> graphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">this<SPAN class="punctuation token">.</SPAN>Point</SPAN><SPAN class="punctuation token">(</SPAN>point<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">markerSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">128</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">)</SPAN>
<SPAN class="keyword token">this</SPAN><SPAN class="punctuation token">.</SPAN>map<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphic<SPAN class="punctuation token">)</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>Thanks
