I'm looking to create a line graph in ArcGIS 10.4 similar to this one:
As you can see, the bottom axis consists of various elemental (text) values. The Y-axis shows the elemental values, displayed on a logarithmic scale. Each vertical line corresponds with a single row of data - the Cs, Rb, Ba, etc. values (see first table below).
The data is received in the following (shapefile/geodatabase) format:
If I rotate the data (in Excel, using the transpose tool), I get a table that ArcGIS can read and create the appropriate graph for (each series - Sample1, Sample3, Sample3, etc. - corresponds to a new vertical line tab in the graph); however, then I cannot then display the points in a map:
I'm looking for any solutions, programmatic or otherwise, to be able to use one shapefile/feature class to create the graph with multiple vertical lines corresponding to each row of data. This is important because the clients want to be able to select some of the points on the map and have those selected points mirrored in the graph.
