I am calculating a field with arcpy, but I have not been able to obtain the expected results.
expression2="getClass(!DESCRIPCION!)"
codeblock2="""def getClass(DESCRIPCION):
if '"DESCRIPCION" LIKE ' + "'%CODE%":
return 1 """
arcpy.CalculateField_management(in_table=out_gdb + "\Compilado\AccesoriosLineasMecanicas",
field="TIPO_EMPALME",
expression=expression2,
expression_type="PYTHON_9.3",
code_block=codeblock2)for all records in the TIPO_EMPALME field the result is 1, I should do a filter for %CODE%
