Hi All
Got the sample code from the link below
https://developers.arcgis.com/javascript/latest/sample-code/popup-custom-action/index.html
I have modified the attribute table to fit to my attribute table.
so from the sample if you click on the bewrey info, instead of linking to a website.
I want to Location attribute to be return as a table or json.
see the code below. I have set var info to get the LOCATION. How do I parse it so it shows as as a json format or table?
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>Custom popup actions per feature attribute - 4.4</title>
<style>
body {
font-family: sans-serif;
padding: 0;
margin: 0;
height: 100%;
width: 100%;
overflow: hidden;
#viewDiv {
position: absolute;
right: 0;
left: 0;
top: 0;
bottom: 0;
</style>
<script>
require([
"esri/Map",
"esri/views/MapView",
"esri/layers/FeatureLayer",
"dojo/domReady!"
], function(
Map, MapView, FeatureLayer
var map = new Map({
basemap: "streets-navigation-vector"
var view = new MapView({
container: "viewDiv",
map: map,
center: [0.46564130, 51.736810] ,
zoom: 17
* Add feature layer
// sampling of breweries
var featureLayer = new FeatureLayer({
outFields: ["*"],
// definitionExpression: "country = 'United States'",
// add a custom action
popupTemplate: {
title: "{name}",
content: [{
type: "fields",
fieldInfos: [{
fieldName: "LOCATION"
fieldName: "address1",
label: "address"
fieldName: "city"
fieldName: "state"
fieldName: "phone"
fieldName: "website"
actions: [{
image: "beer.png",
title: "Brewery Info"
map.add(featureLayer);
var resultsTable = dom.byId("tbl");
function showResults(response) {
var results = response.results;
// Clear the cells and rows of the table to make room for new results
resultsTable.innerHTML = "";
if (results.length === 0) {
resultsTable.innerHTML = "<i>No results found</i>";
loadingImg.style.visibility = "hidden";
return;
view.then(function() {
var popup = view.popup;
popup.viewModel.on("trigger-action", function(event) {
if (event.action.id === "find-ADDRESS") {
var attributes = popup.viewModel.selectedFeature.attributes;
// Get the "website" field attribute
var info = attributes.LOCATION;
// Make sure the "website" attribute value is not null
if (info !== null) {
// Open up a new browser using the URL value in the 'website' field
//CELL.open(info.trim());
showResults();
// If the "website" value is null, open a new window and Google search the name of the brewery
</script>
</head>
<body class="light">
<div id="viewDiv">
</div>
</body>
</html>
