For some reason I am unable to sort query results using the orderByFields parameter when I also pass data in the geometry query parameter. I have tried on multiple different service layers (both arcgis online and hosted internally).
Testing it here it works correctly however:
https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer/0/query?where=1%3D1&text=&objectIds=&time=&geometry=%7B%22spatialReference%22%3A%7B%22wkid%22%3A102100%7D%2C%22xmin%22%3A-10726864.061925028%2C%22ymin%22%3A4927441.778913066%2C%22xmax%22%3A-10560537.088376528%2C%22ymax%22%3A5074200.873220565%7D&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&relationParam=&outFields=*&returnGeometry=true&returnTrueCurves=false&maxAllowableOffset=&geometryPrecision=&outSR=&having=&returnIdsOnly=false&returnCountOnly=false&orderByFields=OBJECTID+ASC&groupByFieldsForStatistics=&outStatistics=&returnZ=false&returnM=false&gdbVersion=&historicMoment=&returnDistinctValues=false&resultOffset=0&resultRecordCount=10&queryByDistance=&returnExtentOnly=false&datumTransformation=¶meterValues=&rangeValues=&quantizationParameters=&featureEncoding=esriDefault&f=html
These two query strings give the exact same results:
query?where=1%3D1&objectIds=&time=&geometry=%7B"spatialReference"%3A%7B"wkid"%3A102100%7D%2C"xmin"%3A-10726864.061925028%2C"ymin"%3A4927441.778913066%2C"xmax"%3A-10560537.088376528%2C"ymax"%3A5074200.873220565%7D&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+ASC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
query?where=1%3D1&objectIds=&time=&geometry=%7B"spatialReference"%3A%7B"wkid"%3A102100%7D%2C"xmin"%3A-10726864.061925028%2C"ymin"%3A4927441.778913066%2C"xmax"%3A-10560537.088376528%2C"ymax"%3A5074200.873220565%7D&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+DESC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
When I remove the geometry query parameter sorting works exactly as expected
query?where=1%3D1&objectIds=&time=&geometry=&geometryType=esriGeometryEnvelope&inSR=102100&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=*&returnHiddenFields=false&returnGeometry=true&featureEncoding=esriDefault&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnQueryGeometry=false&returnDistinctValues=false&cacheHint=false&orderByFields=OBJECTID+DESC&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=0&resultRecordCount=10&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=html
Here is my layer information:
<SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"currentVersion"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">10.7</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"id"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HydroAddressPointswithQC2500RandomV7"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Feature Layer"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"serviceItemId"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"0b6195a200bf49a1b47abd75f900addd"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"displayField"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HydroAddressID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"description"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"copyrightText"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"defaultVisibility"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"editingInfo"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"lastEditDate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1584369476377</SPAN>
<SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"relationships"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isDataVersioned"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsAppend"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsCalculate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsASyncCalculate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsTruncate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsAttachmentsByUploadId"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsAttachmentsResizing"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsRollbackOnFailureParameter"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsStatistics"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsExceedsLimitStatistics"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsAdvancedQueries"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsValidateSql"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsCoordinatesQuantization"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsFieldDescriptionProperty"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQuantizationEditMode"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsApplyEditsWithGlobalIds"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsReturningQueryGeometry"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"advancedQueryCapabilities"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"supportsPagination"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsPaginationOnAggregatedQueries"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryRelatedPagination"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryWithDistance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsReturningQueryExtent"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsOrderBy"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsDistinct"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryWithResultType"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsSqlExpression"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsAdvancedQueryRelated"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsCountDistinct"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsPercentileStatistics"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsLod"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryWithLodSR"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportedLodTypes"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"geohash"</SPAN>
<SPAN class="string token">"supportsReturningGeometryCentroid"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryWithDatumTransformation"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsHavingClause"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsOutFieldSQLExpression"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsMaxRecordCountFactor"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsTopFeaturesQuery"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsDisjointSpatialRel"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"supportsQueryWithCacheHint"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="string token">"useStandardizedQueries"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"geometryType"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriGeometryPoint"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"minScale"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"maxScale"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"extent"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"xmin"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">177.10755675532565</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymin"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">13.256663054422972</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"xmax"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">145.92024380577055</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ymax"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">71.019395373096984</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"spatialReference"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"wkid"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4269</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"latestWkid"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4269</SPAN>
<SPAN class="string token">"drawingInfo"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"renderer"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"simple"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"symbol"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"type"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"esriSMS"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"style"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="string token">"esriSMSCircle"</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">115</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">76</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"size"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">10</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"angle"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"xoffset"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"yoffset"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"outline"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">{</SPAN><SPAN class="string token">"color"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="number token">255</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"width"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"scaleSymbols"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"transparency"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN><SPAN class="string token">"labelingInfo"</SPAN><SPAN class="punctuation token">:</SPAN><SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"allowGeometryUpdates"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"hasAttachments"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"htmlPopupType"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriServerHTMLPopupTypeAsHTMLText"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"hasMetadata"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"hasM"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"hasZ"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"enableZDefaults"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"zDefault"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"objectIdField"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"uniqueIdField"</SPAN> <SPAN class="punctuation token">:</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isSystemMaintained"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN>
<SPAN class="string token">"globalIdField"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"typeIdField"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">""</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"fields"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeOID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"sqlType"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"sqlTypeOther"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"nullable"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"editable"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"domain"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"defaultValue"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HydroAddressID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeString"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HydroAddressID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">40</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"nullable"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"editable"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"AddressDate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeDate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"AddressDate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"FeatureType"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"FeatureType"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">60</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OnNetwork"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeInteger"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OnNetwork"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"codedValue"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"NoYesDomain"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"codedValues"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"No"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"code"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Yes"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"code"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">130</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceAgency"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceAgency"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceDataset"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceDataset"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceFeatureURL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SourceFeatureURL"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Catchment"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"type"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFieldTypeDouble"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Catchment"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HU"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"HU"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">16</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ReachCode"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ReachCode"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"length"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">14</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Measure"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Measure"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ReachSMDate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"ReachSMDate"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalReachCode"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalReachCode"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalMeasure"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalMeasure"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalRCMatch"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OriginalRCMatch"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SnapTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SnapTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SnapDistance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"SnapDistance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"InSnapTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"InSnapTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"QCTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"QCTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"InQCTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"InQCTolerance"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"QCApproved"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"alias"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"QCApproved"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"indexes"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"PK__HYDROADD__F4B70D856D3291D3"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"fields"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"OBJECTID"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isAscending"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isUnique"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">true</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"name"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"user_3341.HYDROADDQC_HYDROADDRESSPOINTSWITHQC2500RANDOMV7_Shape_sidx"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"fields"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Shape"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"isUnique"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"types"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"templates"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN>
<SPAN class="string token">"drawingTool"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"esriFeatureEditToolPoint"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"prototype"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"attributes"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN>
<SPAN class="string token">"InQCTolerance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"QCApproved"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HydroAddressID"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"AddressDate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"FeatureType"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"OnNetwork"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SourceID"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">" "</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SourceAgency"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SourceDataset"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SourceFeatureURL"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Catchment"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"HU"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ReachCode"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"Measure"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"ReachSMDate"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"OriginalReachCode"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"OriginalMeasure"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"OriginalRCMatch"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">null</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SnapTolerance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"SnapDistance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"InSnapTolerance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"QCTolerance"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN>
<SPAN class="string token">"supportedQueryFormats"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"JSON, geoJSON, PBF"</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"hasStaticData"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"maxRecordCount"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">2000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"standardMaxRecordCount"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">32000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"standardMaxRecordCountNoGeometry"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">32000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"tileMaxRecordCount"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">8000</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"maxRecordCountFactor"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="number token">1</SPAN><SPAN class="punctuation token">,</SPAN>
<SPAN class="string token">"capabilities"</SPAN> <SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"Query"</SPAN>
<SPAN class="punctuation token">}</SPAN>j<SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
