I am trying to configure the print widget available within the Web AppBuilder (which comes with ArcGIS Portal 10.7.1) and it does not work when there is a secured map service inside the webmap.
Background:
1. Have tried to use ArcMap to publish a custom print service with credentials embedded, this seems to work fine for secured service. But, the vector tile from the webmap disappears.
2. Have tried to publish a custom print service from ArcGIS Pro..work fine so long as there is no secured service in the webmap else comes up with an error.
