Hi All,
I am having some trouble with the Identity manager. In FF and Chrome things work great, but Internet Explorer is misbehaving... surprise surprise! The issue I am having is that the Identity Manager dialog to connect to secure services will only show up occasionally when the map loads. I have been checking the forums and some folks say I need to add https urls to my proxy config file. Did that. Still misbehaving... any other suggestions? Is there are a way to build and initiate an identity manager on map load? Simply adding in the right modules, i.e. (IdentityManager, esri/arcgis/utils, Dialog...) doesnt seem to do the trick like some of the docs mention. The process is getting aborted occasionally as you see below in the image... Any help would be very much appreciated!
Thanks!
