I am working on automating OD cost matrix runs and am trying to figure out why running the data in arcpy gives a significantly different result then when run in arcmap. I have checked every setting (i believe) and they all seem to be the same. It uses the same network and the same origins and destinations.
At first i thought it might have been a projection issue and i have tested the runs with everything in the same projection and still the results are different.
Does anyone have any idea on why this would be?
Matt
