Just exploring Hosted Feature Layer relationship persistence in AGOL.
I have a FGDB PointFC, with a 1:M relationship class to a related table. I have:
PointFC
ABField (for def qry)
GlobalID (1) (DataType- GlobalD)
Relationship defined GlobalID to Point_FK
RelatedTable
Point_FK (M) (DataType - GUID)
GlobalID (DataType- GlobalD)
As guidance suggests..
In mxd (or aprx) I have a definition query set on ABField, to create two layers (pointing at the same source FC) which I thought should both 'honor' the relationship class.
On publishing as a hosted feature service to AGOL, and subsequently when using the edit widget to add a related table record:
GlobalID from the source FC is correctly propagated from layer 0 (A) to the related table
GlobalID from the source FC is not correctly propagated from layer 1 (B) to the related table
So my question is, is only a single layer (source) supported for relationship classes when publishing to AGOL? Will play with other options, but interested in views.
Happy to share the WebApp..
