I've had some previous help from Jennifer and Joe Hershman on how to handle and edit a related table (feature class). I have everything working with a featureDataGrid but now I want to use a featureDataForm and I thought it would be an easy switch but it is proving harder than I expected. Here's some of my code:XAML
<!-- RELATED LINK RESOURCE-->
<common:HierarchicalDataTemplate x:Key="TreeViewItemTemplate">
<StackPanel Orientation="Horizontal" Margin="0">
<!--<Ellipse Fill="Transparent" Height="6" Width="6" StrokeThickness="2" Stroke="Black" Margin="0,0,10,0"/>-->
<TextBlock Text="APN: " HorizontalAlignment="Left" FontSize="10" Margin="0"/>
<TextBlock x:Name="TextBlockRelate" Text="{Binding Attributes[APN]}" HorizontalAlignment="Left" FontSize="10"/>
</StackPanel>
</common:HierarchicalDataTemplate>
<!--END RELATED LINK RESOURCE-->
XAML
<!-- GRID FOR RELATED (AP) -->
<userControls:DraggableWindow x:Name="RelateResultsDisplay" IsOpen="False"
VerticalAlignment="Bottom" HorizontalAlignment="Right"
Margin="15" Effect="{StaticResource dropShadow}" Title="RELATED WORK RESULTS TABLE" Background="Black">
<Grid HorizontalAlignment="Stretch" VerticalAlignment="Stretch" Width="Auto" Height="Auto" >
<Border Effect="{StaticResource miniDropShadow}" Style="{StaticResource RibbonElementBorder}" Padding="15" Margin="10">
<Grid x:Name="RelatedRowsGrid" HorizontalAlignment="Right"
VerticalAlignment="Top" MinHeight="170" Width="Auto">
<Grid.ColumnDefinitions>
<ColumnDefinition Width="140" />
<ColumnDefinition MaxWidth="600" />
</Grid.ColumnDefinitions>
<StackPanel Orientation="Vertical" Margin="1,-5,1,5">
<TextBlock Margin="1,0,5,1" TextWrapping="Wrap" Grid.Column="0"
Text="Click to see relates: "
FontSize="10" FontFamily="Arial" Foreground="#FFFFFFFF" />
<basics:TreeView x:Name="SelectedWellsTreeView" MaxHeight="180" Grid.Column="0" Margin="1"
ItemsSource="{Binding}" BorderBrush="Gray" BorderThickness=".5"
SelectedItemChanged="SelectedWellsTreeView_SelectedItemChanged"
ItemTemplate="{StaticResource TreeViewItemTemplate}"
</StackPanel>
<esriWidgets:FeatureDataGrid Grid.Column="1" Grid.Row="1" x:Name="MyFDG" Height="180"
Style="{StaticResource FeatureDataGridRelateStyle1}" />
</Grid>
</Border>
</Grid>
</userControls:DraggableWindow>
<!--END GRID FOR RELATED (AP) -->
CODE BEHIND
//For FDG -- Jennifer's code
// l = Map.Layers["AP"] as FeatureLayer;
l = new FeatureLayer()
ID = "MyLayer",
Url = "http://myserver/ArcGIS/rest/services/Relate/FeatureServer/1",
Mode = FeatureLayer.QueryMode.Snapshot,
l.OutFields.Add("*");
l.Initialized += (s, e) =>
if (l.InitializationFailure != null)
MessageBox.Show(l.InitializationFailure.Message);
l.InitializationFailed += (s, e) =>
l.Initialized += new EventHandler<EventArgs>(l_Initialized);
l.Initialize();
MyFDG.GraphicsLayer = l;
MyFeatureDataForm.FeatureLayer = l;
queryTask = new QueryTask("http://dgpdch03/ArcGIS/rest/services/Relate/MapServer/0");
queryTask.ExecuteCompleted += QueryTask_ExecuteCompleted;
queryTask.ExecuteRelationshipQueryCompleted += QueryTask_ExecuteRelationshipQueryCompleted;
queryTask.Failed += QueryTask_Failed;
//End for relate
//CODE FROM JOE, JENNIFER, AND INTERACTIVE SDK
void l_Initialized(object sender, EventArgs e)
var l = sender as FeatureLayer;
l.Initialized += (s, f) =>
l.UpdateCompleted += UpdateCompleted;
l.UpdateFailed += UpdateFailed;
l.Update();
private void UpdateFailed(object sender, TaskFailedEventArgs e)
MessageBox.Show(e.Error.Message);
private void UpdateCompleted(object sender, EventArgs e)
MessageBox.Show("WooHoo!");
FeatureLayer l;
private void deleterowButton_Click(object sender, System.Windows.RoutedEventArgs e)
if (l != null && l.LayerInfo != null && l.LayerInfo.Fields != null)
l.Graphics.Remove(MyFDG.SelectedGraphics[0]);
private void addrowButton_Click(object sender, RoutedEventArgs e)
var g = new Graphic();
foreach (var f in l.LayerInfo.Fields)
g.Attributes[f.Name] = null;
g.Attributes["GEN_PLAN"] = "GPk";
g.Attributes["APN"] = relateIDstring;
else
l.Graphics.Add(g);
private void SelectedWellsTreeView_SelectedItemChanged(object sender, RoutedPropertyChangedEventArgs<object> e)
if (e.OldValue != null)
Graphic g = e.OldValue as Graphic;
g.UnSelect();
g.SetZIndex(0);
if (e.NewValue != null)
Graphic g = e.NewValue as Graphic;
g.Select();
g.SetZIndex(1);
RelationshipParameter relationshipParameters = new RelationshipParameter()
ObjectIds = new int[] { Convert.ToInt32(g.Attributes[SelectedWellsTreeView.Tag as string]) },
OutFields = new string[] { "*" },
RelationshipId = 0,
OutSpatialReference = Map.SpatialReference,
queryTask.ExecuteRelationshipQueryAsync(relationshipParameters);
relateIDstring = g.Attributes["APN"].ToString();
void QueryTask_ExecuteRelationshipQueryCompleted(object sender, RelationshipEventArgs e)
RelationshipResult pr = e.Result;
if (pr.RelatedRecordsGroup.Count == 0)
l.Where = "1=0"; //remember _featureLayer is l
else
foreach (var pair in pr.RelatedRecordsGroup)
IEnumerable<Graphic> graphics = e.Result.RelatedRecordsGroup.First().Value;
l.Where = null; //remember _featureLayer is l
int[] objectIds = graphics.Select(g => (int)g.Attributes["OBJECTID_1"]).ToArray();
//now set the ObjectIDs on our FeatureLayer
l.ObjectIDs = objectIds;
l.Update();
// MyFeatureDataForm.FeatureLayer = l; //HERE"S WHERE I THOUGHT I COULD JUST SET FEATUREDATAFORM
All The code works and everything is great. I can add and delete records and see and edit all the relate information. All I'm doing is adding a FeatureDataForm to my xamlXAML
<Border x:Name="FeatureDataFormBorder" Visibility="Visible"
HorizontalAlignment="Right" VerticalAlignment="Top" Margin="10,10,10,0" Width="300" Height="300" >
<Border.Effect>
<DropShadowEffect Color="Black" Direction="-45" BlurRadius="20" Opacity=".75" />
</Border.Effect>
<esri:FeatureDataForm x:Name="MyFeatureDataForm"
IsReadOnly="False" LabelPosition="Left" />
</Border>
And in the CODE BEHIND I thought I could just set the source (FeatureLayer) for the FeatureDataForm in the QueryTask_ExecuteRelationshipQueryCompleted right after I set the GraphicLayer for my FeatureDataGrid...see red code above.Shouldn't it be as simple as my thought process since everything is working for my FDG.ThanksNathalie
