I have been using the Vehicle Routing Problem within ArcMap but it keeps running out of memory so I want to try it in Pro as it is 64bit and can utilise all of the RAM on my machine.
However, I don't see how you can populate the orders, routes, depots etc tables. In arcmap when you create a new vehicle routing problem, these layers show in the network analyst window with the correct schema and you can right click and load data. This allows you to map fields from an existing feature class to the required fields in orders, depots etc. Is there a way to do this in pro? All I can see is the ability to add a whole table or enter data manually, not load and map existing data.
