I'm working on a custom drawbylist widget and I have trouble with loading the map on the center pane. I need my custom widget to go in the left pane and the map in the center, like shown in the example below. I'm following the example below, as my baseline.
http://developers.arcgis.com/javascript/samples/ags_MapContainerSplitLeft/ .
I have two issue, the tab is not showing up and the map is not in the center. Could you please help .( I'm running on a Tomcat server to load templates and json files)
