i have link MapServer(cached) http://localhost:6080/arcgis/rest/services/NenChung2909 i want add this MapServer above Esri MapServer, but when i add two MapServer then my MapServer isnot show, Esri MapServer is show. please help me! thank you! This is my code:
<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples
on iOS devices-->
<title>Terrain basemap with custom data</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
#map{padding:0;}
</style>
<script>var dojoConfig = {parseOnLoad: true};</script>
<script src="http://js.arcgis.com/3.11/"></script>
<script>
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("esri.map");
var map;
function init() {
map = new esri.Map("map", {
//Add the terrain service to the map. View the ArcGIS Online site for services http://arcgisonline/home/search.html?t=content&f=typekeywords:service
var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/World_Terrain_Base/MapServer");
map.addLayer(basemap);
var layer = new esri.layers.ArcGISTiledMapServiceLayer("http://localhost/arcgis/rest/services/NenChung2909/NenChungDongNai/MapServer");
map.addLayer(layer);
//add custom services in the middle. This is typically data like demographic data, soils, geology etc.
//This layer is typically partly opaque so the base layer is visible.
dojo.ready(init);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit.layout.BorderContainer"
data-dojo-props="design:'headline', gutters:false"
style="width: 100%; height: 100%; margin: 0;">
<div id="map"
data-dojo-type="dijit.layout.ContentPane"
data-dojo-props="region:'center'"
style="overflow:hidden;">
</div>
</div>
</body>
</html>
I see sample of esri add three MapServer this sample worked perfect. Link this sample:
Add a terrain basemap with operational layer | ArcGIS API for JavaScript
