Hi, I'm trying to replicate this Onclick event for a sublayer in a ArcGISDynamicMapServiceLayer sample but i hadn't success.
Mine scenario are: I've a menu each action can show a different view of data (layers) one of those are a time TimeSlider, the time slider works fine but a need to add a function for display some data after doing a click on certain point on the map.
function inittimeSlider() {
try{
var opLayer = new esri.layers.ArcGISDynamicMapServiceLayer(document.getElementById('hUrl').value);
opLayer.setVisibleLayers([CapaPosicion.FALLAS.value]);
opLayer.id = 'timeSlider';
opLayer.opacity = 0.6;
var component = dijit.registry.byId("timeSliderDiv");
if (component) {
//destroy it
dojo.domConstruct.destroy(component);
dijit.registry.remove(timeSlider)
timeSlider.destroy()
timeSlider = new esri.dijit.TimeSlider({
style: "width: 100%;"
}, dojo.dom.byId("timeSliderDiv"));
map.setTimeSlider(timeSlider);
var timeExtent = new esri.TimeExtent();
timeExtent.startTime = new Date("01/01/2015 UTC");
timeExtent.endTime = new Date("08/31/2015 UTC");
timeSlider.setThumbCount(2);
timeSlider.createTimeStopsByTimeInterval(timeExtent, 1, "esriTimeUnitsMonths");
timeSlider.setThumbIndexes([0, 1]);
timeSlider.setThumbMovingRate(2000);
timeSlider.startup();
//add labels for every other time stop
var labels = dojo._base.array.map(timeSlider.timeStops, function (timeStop, i) {
//if ( i % 2 === 0 ) {
return timeStop.getUTCFullYear();
//} else {
return "";
timeSlider.setLabels(labels);
timeSlider.on("time-extent-change", function (evt) {
var startValString = Meses(evt.startTime.getUTCMonth());
var endValString = Meses(evt.endTime.getUTCMonth());
dojo.dom.byId("daterange").innerHTML = "<i>" + startValString + " a " + endValString + " " + "<\/i>";
map.addLayers([opLayer]);
map.on("load", initFunctionality);
function initFunctionality() {
map.on("click", doIdentify);
var identifyTask = new esri.tasks.IdentifyTask(document.getElementById('hUrl').value);
var identifyParams = new esri.tasks.IdentifyParameters();
identifyParams.tolerance = 3;
identifyParams.returnGeometry = true;
identifyParams.layerIds = [CapaPosicion.FALLAS.value];
identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
dojo.on(identifyTask, "complete", function (event) {
array.forEach(event.results, function (feature) {
if (feature.layerName == "timeSlider") {
alert('123456789');
function doIdentify(event) {
map.graphics.clear();
identifyParams.geometry = event.mapPoint;
identifyParams.mapExtent = map.extent;
identifyTask.execute(identifyParams)
catch (e) {
console.log("Error : " + e);
HideProgress();
at first I thought it was the same way to what is done in the onclick of esri.layers.FeatureLayer,
exist another way ? or I have something wrong that can not see ?
