I'm struggling to get the Temporal Renderer to work with real-time data. The renderer seems to work w my UniqueValueRenderer as the ObservationRenderer of the Temporal Renderer, but the Ager doesn't seem to work. I have been able to get the Temporal Renderer w the Ager working with historic data and a time slider, but w the real-time data it is not working. I must have some setting incorrect or something somewhere. I've tried to look on-line but haven't found much and a lot of the ESRI examples for real-time data are not working or there are no hurricanes or earthquakes occurring at this time. I'm using a Feature Collection Object to create my Feature Layer and I'm NOT using a TimeSlider, since this is real-time data. I believe or have read that if the start and endTime extent are set to the same time, then it should be set for a time instant which I have since data is added in real-time. Let me know if you see anything that I don't have set-up correctly. I have looked at the time formats as well for gps_time and all seems to be correct in this format: Thu Jul 16 2015 11:38:54 GMT-0600 (MDT)
Thanks! - Carisa
Some of the renderer code.. trying to keep it as simple as possible just to get this working for now:
var simplerMarker = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE,12,new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
new Color("red"), 1),
new Color("red"));
var observationRend = new UniqueValueRenderer(simplerMarker,"group");
observationRend.addValue("SolidWaste",new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE,10,new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL),new Color([255, 153, 0])));
observationRend.addValue("StormSweeper",new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE,10,new SimpleLineSymbol(SimpleLineSymbol.STYLE_NULL),new Color([9, 112, 84])));
var infos = [
{ minAge: 0, maxAge: 15, size: 15},
{ minAge: 15, maxAge: 24, size: 11},
{ minAge: 24, maxAge: Infinity, size: 6}
var observationAger = new TimeClassBreaksAger(infos, TimeClassBreaksAger.UNIT_SECONDS);
rendererBC = new TemporalRenderer(observationRend,null,null,observationAger);
Then I'll set the map's time extent since I'm not using a Time Slider:
var timeExtent = new TimeExtent();
var now = new Date();
timeExtent.startTime = now;
timeExtent.endTime = now;
map.setTimeExtent(timeExtent);
Feature Collection object set-up for the Feature Layer:
//Create Feature Layer for Vehicles
var featureCollection = {
"layerDefinition": null,
"featureSet": {
"features": [],
"geometryType": "esriGeometryPoint"
featureCollection.layerDefinition = {
"geometryType": "esriGeometryPoint",
"objectIdField": "OBJECTID",
"timeInfo": {
"startTimeField": "gps_date",
"endTimeField": null,
"trackIdField": "unit_id",
"timeReference": "Mountain Standard Time", //do I need to set this?
"timeInterval": 15,
"timeExtent": ["2015/07/16 00:00:00 UTC", "2015/07/16 00:00:00 UTC"],
"timeIntervalUnits": "esriTimeUnitsSeconds",
"exportOptions": {
"useTime": true,
"timeDataCumulative": true,
"timeOffset": null,
"timeOffsetUnits": null
"fields": [{
"name": "OBJECTID",
"alias": "OBJECTID",
"type": "esriFieldTypeOID"
"name": "unit_id",
"alias": "unit_id",
"type": "esriFieldTypeString"
"name": "gps_date",
"alias": "gps_date",
"type": "esriFieldTypeDate"
}, {....etc.
breadcrumbLayer = new FeatureLayer(featureCollection, {
mode: FeatureLayer.MODE_SNAPSHOT,
trackIdField: "unit_id",
outFields: ["*"]
//render a particular time extent - do I need this??
timeExtent.startTime = new Date("07/16/2015 UTC");
timeExtent.endTime = new Date("07/16/2015 UTC");
breadcrumbLayer.setTimeDefinition(timeExtent);
