So I'm new to Javascript. I'm working with two templates, Basemap gallery | ArcGIS API for JavaScript 3.17 and
Popup widget | ArcGIS API for JavaScript 3.17. It works, but the issue is that the map service layer doesn't load until I pick a basemap from the dropdown. I have the map variable set to a default basemap of light gray canavas, and the default view hovers over the US, but it seems like this is being overridden. It probably have something out of order.
Thanks!
Here is my code:
<!DOCTYPE html>
<html>
<head>
<title>Forecast Analysis</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.17/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.17/esri/css/esri.css">
<style>
html, body {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
.esriScalebar {
padding: 20px 20px;
#map {
padding: 0;
</style>
<script src="https://js.arcgis.com/3.17/"></script>
<script>
var map;
require([
"esri/config",
"esri/map",
"esri/dijit/BasemapGallery",
"esri/arcgis/utils",
"esri/dijit/Popup",
"esri/dijit/PopupTemplate",
"esri/layers/FeatureLayer",
"esri/symbols/SimpleMarkerSymbol",
"esri/tasks/GeometryService",
"dojo/dom-construct",
"dojo/parser",
"esri/Color",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/TitlePane",
"dojo/domReady!"
function (
esriConfig, Map, BasemapGallery, arcgisUtils, Popup, PopupTemplate, FeatureLayer,
SimpleMarkerSymbol, GeometryService, domConstruct, parser, Color
parser.parse();
map = new Map("map", {
basemap: "gray",
center: [38.5, -96.8],
zoom: 4,
infoWindow: popup
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
map: map
}, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function(msg) {
console.log("basemap gallery error: ", msg);
var popupOptions = {
markerSymbol: new SimpleMarkerSymbol("circle", 32, null,
new Color([0, 0, 0, 0.25])),
marginLeft: "20",
marginTop: "20"
//create a popup to replace the map's info window
var popup = new Popup(popupOptions, domConstruct.create("div"));
var popupTemplate = new PopupTemplate({
title: "Forecast Analysis",
fieldInfos: [
fieldName: "Name",
visible: true,
label: "Location"
fieldName: "Lat",
visible: true,
label: "Latitude"
fieldName: "Lon",
visible: true,
label: "Longitude",
showAttachments: true
//create a feature layer based on the feature collection
var featureLayer = new FeatureLayer("http://gis.mymetcon.com/arcgis/rest/services/Forecast_Analysis/MapServer/0",
mode: FeatureLayer.MODE_SNAPSHOT,
infoTemplate: popupTemplate,
outFields: ["Lat", "Lon", "Name"]
map.addLayer(featureLayer);
</script>
</head>
<body class="claro">
<div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'"
style="width: 100%; height: 100%; margin: 0;">
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"
style="border:1px solid #000;padding:0;">
<div style="position:absolute; right:20px; top:10px; z-Index:999;">
<div data-dojo-type="dijit/TitlePane" style="font-family:arial;background-color:lightgray"
data-dojo-props="title:'Switch Basemap', closable:false, open:false">
<div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:480px; overflow:auto; font-family:arial;background-color:lightgray">
<div id="basemapGallery"></div>
</div>
</div>
</div>
</div>
</div>
</body>
</html><SPAN class="line-numbers-rows"><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN><SPAN></SPAN></SPAN>
