Hi
Is there a way to use the split operation to remove the entry and exit parts of a street and keep the portion which has the regular street width?
some variation of
split(u, uvSpace, 0)
Here Street and intersection shape UV—ArcGIS CityEngine Resources | Documentation
the docs says that :
The central region of the geometry is normalized along its length from 0 to 1, and across its width by 0 to the number of lanes.
The entry and exit of a street shape are parameterized to blend with the central region. For example the entry (above, blue) and exit (green) u-values are oriented and scaled to match the central region (red). The entry has negative U values, and the exit has U values greater than 1.
How can I say, "cut everything with UVs which are out of the 0,1 range?
Cheryl Lau, Simon Haegler any idea?
A
