Hi
I am trying to update a python addin for ArcGIS, which is a toolbar with four buttons. Mostly what the buttons do is transfer data from multiple personal geodatabases to a single oracle database. I have one script for each button and I want to call these four scripts in a single script.
This is the script which I am trying to call the other four scripts into. The issue that I am having is that the from package import * is causing the four buttons to fall over (they appear as a red circle with a line through it and the word missing next to it). I have tried keeping all four scripts within a single script but I would prefer to keep them separate. Everything I try and do seems to cause the buttons to fall over, even if it is just adding a print statement.
I have tried putting print dir() after importing package. The classes from the four scripts are being imported fine as far as I can tell.
Can anyone see a reason why this script is causing the buttons in the toolbar to fall over?
I have included the __init__.py script at the bottom which I copied from a similar question (http://stackoverflow.com/questions/5134893/importing-python-classes-from-different-files-in-a-subdirectory). The __init__.py and the four scripts (Append_Models_Oracle.pv, SAGIS_to_Oracle.py, Import_GIS1_csv.py and Import_Determinands_csv.pv) are all located within the package folder.
import arcpy
import pythonaddins
import os
import sys
import getopt
import fnmatch
import traceback
import pyodbc
import csv
from datetime import datetime
import logging
class AppendModelsOracle(object):
"""Implementation for Append_Models_Oracle.button (Button)"""
def __init__(self):
self.enabled = True
self.checked = False
def onClick(self):
package.Append_Models_Oracle.AppendModelsOracle()
class SAGIStoOracle(object):
"""Implementation for SAGIS_to_Oracle.button (Button)"""
def __init__(self):
self.enabled = True
def onClick(self):
package.SAGIS_to_Oracle.SAGIStoOracle()
class ImportGIS1CSV(object):
"""Implementation for Import_GIS1_CSV.button (Button)"""
def __init__(self):
self.enabled = True
def onClick(self):
package.Import_GIS1_csv.ImportGIS1CSV()
class ImportDeterminandCSV(object):
"""Implementation for Import_determinand_csv.button (Button)"""
def __init__(self):
self.enabled = True
def onClick(self):
package.Import_Determinands_csv.ImportDeterminandCSV()
__init__.py
def _import_package_files():
""" Dynamically import all the public attributes of the python modules
in this file's directory (the package directory) and return a list
of their names.
import os
exports = []
globals_ = globals()
locals_ = locals()
package_path = os.path.dirname(__file__)
package_name = os.path.basename(package_path)
for filename in os.listdir(package_path):
modulename, ext = os.path.splitext(filename)
if modulename[0] != '_' and ext in ('.py', '.pyw'):
# create a package relative subpackage name
subpackage = '{}.{}'.format(package_name, modulename)
module = __import__(subpackage, globals_, locals_, [modulename])
modict = module.__dict__
names = (modict['__all__'] if '__all__' in modict else [name for name in modict if name[0] != '_']) # public names
exports.extend(names)
globals_.update((name, modict[name]) for name in names)
return exports
if __name__ != '__main__':
__all__ = ['__all__'] + _import_package_files() # '__all__' in __all__Thanks in advance for any help,
Ben.
