When I run it with the Test Files provided, the following error shows up.
File "C:\Users\*\Urban Network Analysis Toolbox\src\Centrality_Main.py", line 7, in <module>
from Centrality.Main import main
File "C:\Users\*\Urban Network Analysis Toolbox\src\Centrality\Main.py", line 28, in <module>
from arcpy import mapping
ImportError: cannot import name 'mapping'
Failed to execute (Centrality).
But even I change mapping into mp in the code, this error repeats for 'from Adjacency_List_Computation import compute_adjacency_list', 'from Centrality_Computation import compute_centrality' and 'from Constants import xyz' from line 36 to 116 of Centrality\Main.py .
This tool was designed to use with ArcGIS 10.2, but I am using ArcGIS Pro 2.4 since it is the version of trail available, is that the reason the toolbox doesn't work? If so, is there any way to fix it?
Alvin
