I'm new to ArcGIS, and I'm having trouble getting graphics I've added to the map programmatically to show up at the desired lat/lng coordinates. Instead they display at (0,0) off the coast of Africa no matter what coordinates are passed in. Here's the code I'm using to create and place the symbols: graphicsLayer = [[AGSGraphicsLayer alloc] init]; [mapView insertMapLayer:graphicsLayer withName:@graphics layer atIndex:1]; AGSGraphic* g; //Create the AGSSimpleMarker Symbol and set some properties AGSSimpleMarkerSymbol* myMarkerSymbol = [AGSSimpleMarkerSymbol simpleMarkerSymbol]; myMarkerSymbol.color = [UIColor blueColor]; myMarkerSymbol.style = AGSSimpleMarkerSymbolStyleDiamond; myMarkerSymbol.outline.color = [UIColor whiteColor]; myMarkerSymbol.outline.width = 3; //Create an AGSPoint (which inherits from AGSGeometry) that //defines where the Graphic will be drawn double lat = [[record objectForKey:@lat] doubleValue]; double lng = [[record objectForKey:@lng] doubleValue]; NSLog(@Point: %f, %f, lat, lng); AGSPoint* myMarkerPoint = [AGSPoint pointWithX:lat y:lng spatialReference:mapView.spatialReference]; //Create the Graphic, using the symbol and //geometry created earlier g = [AGSGraphic graphicWithGeometry:myMarkerPoint symbol:myMarkerSymbol attributes:nil infoTemplateDelegate:nil]; [graphicsLayer addGraphic:g];
The map view is already loaded and displaying correctly when this code is executed. If anyone can shed some light on what I might be missing it would be much appreciated.
