Is there some trick to getting LAS (or LAS Dataset) data in ArcGIS Pro to display as a 3D surface in 3D Scene? In my table of contents the LAS file will appear under "3d Layers" group when I display it as just points and the points appear in 3D as expected, but if I modify the symbology to display it as a surface, then the layer moves down into the "2D Layers" section of the table of contents. At that point the layer is "flattened" so there is no 3D extrusion for the ground elevation and buildings in the source LAS file. I'd like to display my las data as a TIN looking solid surface in my scene if that's possible.
Would also like to try publishing that solid surface to ArcGIS Online, but that's another challenge. I think right now only raster, 3D polygon, 3D point, and 3D point clound are supported as hosted feature types.
Thank you,
Andrew
